71 Rear End numbers - NCRS Discussion Boards
71 Rear End numbers
+ More Options
Posts
  • Tim Lynaugh
    71 Rear End numbers
    Trying to figure out if my 71 has its original rear. On the bottem of the diff housing is the number AWW348E2. Cover has H115 on the pass side. Has a 3871975 casting number on the rear cover. Didnt see any other numbers.
  • Robert E.
    • April 1, 2004
    • 398
    Re: 71 Rear End numbers
    Tim,
    I'm certainly not in the same league as some on this board, but I'll give it a shot.
    AW - 3.08 ratio/Posi
    W - Warren Motive axle
    348 - December 14th
    E2 - Second Shift???
    If I'm wrong, I'm sure someone with more knowledge will correct me.
    Robert
    41801
    • Tim Lynaugh
      Thanks. Is there any way to identify the year? Or is there another code somewhere?
      • Wayne M.
        • March 1, 1980
        • 6414
        I'm not a C3 guy, but ...
        your rear cover is probably 3871(3)75, not (8). The H-11-5 date cast near the edge by the filler plug, means 11th August 1975 (was the same cover casting # in 1965, but they weren't casting dates on covers in 1965).
        Now, on the main carrier, I can't help with the stamped bottom code, but there should be a cast date underneath the driver side 1/2-shaft yoke (same M-D-Y format) which might agree with the timeframe of the rear cover.
