1968 Rear window storage tray mounting - NCRS Discussion Boards
  • Dennis M.
    • April 30, 1988
    • 160
    rear window storage tray mounting dennis moore i have coupe which had the rear window tray but not installed the carpet was not correct so i installed new carpet but when i went to install the window tray found the mounting plate holes behind the carpet should the carpet be cut out for this mount or be mounted over the carpet on the rear bulkhead or mount behind the carpet the assembly manual shows the bracket attached right up against the mounting plate also the engine is in fairly original condition with the exception of the carb which had been replaced the coil on this appears to be the original one but it a
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 1968 Rear window storage tray mounting
    re rear window storage tray mounting gene manno coil is ok on very early car
    • Dennis M.
      • April 30, 1988
      • 160
      re rear window storage tray mounting dennis moore the only problem is the car was built and that seem late for a coil unless there was a coil left on the assembly line and got installed
      • Gene M.
        • April 1, 1985
        • 4232
        re rear window storage tray mounting gene manno i assume you intended which ever it would be to late for a coil maybe some one else could help ya out with that rear tray my ' is conv hdt sorry
