67 Parking Brake Button - NCRS Discussion Boards
  • Ralph E.
    • February 1, 2002
    • 905
    The button on my parking brake just popped off. I have an early car and the button is black. How do I re-install it. Just pushing it back into place does not work.
  • Scott Marzahl
    Re: 67 Parking Brake Button
    I used epoxy and clamped it in place to secure mine during re-assembly after rechroming my handle. The metal rod was probably molded in place originally so just pushing it back in will not work as the plastic has worn away.
    • Page C.
      • February 1, 1979
      • 802
      Hi Scott,
      How did you remove the black plastic part of the handle prior to having it rechroming the metal part
      Page Campbell
      • Scott Marzahl
        After you work the actuator rod from the black button and remove that, the black plastic body basically just slides off the chrome handle with a little work.
        • Ralph E.
          • February 1, 2002
          • 905
          Fixed the parking brake button. Used epoxy glue fit for plastic and metal.
          • Rob A.
            • December 1, 1991
            • 2126
            Ralph,
            I put mine back on with PC7 epoxy paste (True Value carries it) Great stuff. Lightly sand the rod for good adhesion, it won't come off again.
            • Ralph E.
              • February 1, 2002
              • 905
              Thanks Rob, if the stuff I used doesn't hold I try the PC7.
