Tranny & Diff. Fluid Question - NCRS Discussion Boards
+ More Options
Posts
  • Chuck M.
    • February 1, 2002
    • 335
    Hi
    I am planning on changing the transmission and differential fluid and wanted to know what fluid I should be using for both. Thanks for the help.
    Chuck
  • Chuck M.
    • February 1, 2002
    • 335
    Sorry the car is a '67 Coupe...
    with an M20 Muncie. Also has Posi.
    Thanks again
    Chuck
      • 15704
      Re: Tranny & Diff. Fluid Question
      The original specification for each is Mil-L-2105D.
      The modern equivalent is SAE 80W-90 GL-5.
      • Jack W.
        • August 31, 2000
        • 358
        Rec you use the Posi additive from GM too.
          • 15704
          Just in the axle. *NM*
          • Jack W.
            • August 31, 2000
            • 358
            Posi Additive to the Posi only, right! : ) *NM*
            • Chuck M.
              • February 1, 2002
              • 335
              Where is the best place to buy this?
              Can I use the 80W-90 GL-5 in both tranny and diff? Thanks again for the help.
              Chuck
                • 15704
                That's the spec for both *NM*
                  Re: Where is the best place to buy this?
                  Chuck -
                  At your Chevy dealer - GM Diff Lube and GM Posi Additive.
