C-3 tire height & size - NCRS Discussion Boards
  • KEN BUTCHER
    Hello anybody out there?
    I've got 245/60/15 goodyear eagle GT's with the outlined white letter tire on my 75', but I find there is too much wheel well on the rear,so I want to go back to the stock size which was GR70/15. Does anyone know what the height of the stock GR70/15 tire is? and what tire I can replace it with? And at the same time have a tire with about the same height as stock.I still have the original firestone 500 radial spare. It's too bad the firestone 500's had manufacturing problems back in the 70's but even though they were garbage, it would be nice if you could get reproductions.
    Thanks in advance.
    Ken.
  • Kurt B.
    • July 31, 1996
    • 971
    Re: C-3 tire height & size
    Have you tried Coker Tire for reproductions of the Firestone 500 tires?
    They have a web site that might be worth checking.
    Kurt # 26406
    • Wayne P.
      • August 31, 1975
      • 1025
      225-70X15 *NM*
      • Harmon C.
        • August 31, 1994
        • 3228
        For the size of the GR70-15 just measure your spare Firestone 500. Todays replacement is a 225-70R15. Coker told me they will not make any radials in this size because the process to make radials is lots more costly and the demand is too low. Lyle
        Lyle
        • Paul B.
          • April 30, 1995
          • 482
          P225/70R-15 size tires are slightly, slightly larger than the "original" GR-70/15 tires. A wider "optional" tire that was used '78-'82 was the P255/60R-15 size tires.
