C2 Wheel Lugs - NCRS Discussion Boards
C2 Wheel Lugs
  • Joe S.
    • April 1, 1996
    • 28
    C2 Wheel Lugs
    I have seen two different headmarkings on standard steel lugnuts; three recessed triangles stamped 120 degrees apart and "RBW." Which of these, if either, is correct for the C2 Corvette?
  • Dave M.
    • June 30, 1999
    • 58
    Re: C2 Wheel Lugs
    Hi Joe, I have an original unrestored '67 and all 20 lug nuts have the 3
    triangles on them. My car is a September built car. Hope this helps some.
    Dave
    • Joe S.
      • April 1, 1996
      • 28
      Re: C2 Wheel Lugs
      Thank you, Dave.
      My 67 has 15 triangle lugs and 5 with RBW. RBW was a common headmarking in that vintage so I am guessing it is also correct.
        Re: C2 Wheel Lugs
        GM bought 400,000 lug nuts per day back then - you can bet there were at LEAST two suppliers, probably three or four.
