71 LS-5 originality - NCRS Discussion Boards
71 LS-5 originality
  • Tim Lynaugh
    71 LS-5 originality
    Know this has probably been gone over many times here. Have gotten some good info, just need help putting it together. Have 71 LS-5 Coupe. No build sheet.Has 26 1/2 radiator,15/16 front sway bar, 9 leaf rear spring, no rear sway bar but evidence that one was once there. But has rear u-bolts not caps on the u-joints. Also has 5600 rpm tach. Looks original. Has non-original block. Do these things point to a original BB?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 71 LS-5 originality
    I thought the radiator of the big blocks was 27+ inches and the small block base engines like my 70 with air conditioning got a 26 inch radiator. My original owner small block with turbo 400 came from the factory with caps on the shafts.
    • lyndon sharpton
      what evidence do you see? that it had a sway bar.
      • lyndon sharpton
        what is the hood a BB with 454? what about the shifter info on the does it say 454? what about the firewall tag for the timeing? what is on that?
        • Tim Lynaugh
          The firewall tag is missing. Console says 365 hp 454. Know they are easily changed. As for the swaybar, there are areas on the frame where you can tell where the bushings were mounted. Frame must have been painted at some time, can see the outline of the bushings. Hood had been changed to a L88 style.
          • Warren F.
            • December 1, 1987
            • 1516
            Tim:
            For 1971 model, there were 4 engines and 3 tachometer yellow/redline variations. LT-1 & LS-6 use 6300 yellowline. ZQ3 use 5300 yellowline, and LS-5 uses 5600 yellowline.
