C2:67 Valve Cover Gaskets - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Replacing my speedshop aluminum valve covers, which have been on my 327/300Hp since 1968, with original steel covers. Need recommendation on gaskets, cork or Felpro? Have both.
    Can I expect some changes in performance or heating?
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    Re: C2:67 Valve Cover Gaskets
    Factory originals were cork, if the concours matters to you. Don't expect any change in performance/heating.
    One BIG tip on stamped steel valve covers is to MAKE SURE the edges are flat & true before you install them. Run a straight edge along the bottom lips and if they're warpped in the typical places (beneath fastener locations), lay them on a flat surface and tap them back flat/true before going any further.
    Then, when installing, do NOT over-torque the bolts! Remember, the gasket needs to 'breathe' during engine thermal cycles and that expansion/contraction is built into GM's recommended torque specs.
    • Ed Jennings
      Also, don't forget the "flying saucer" shaped washers that are designed to spread the load on the stamped steel covers.
