I have totally run out of ideas to get my brake lights on my '58 to work.
All other lights work. I have power to the brake switch orange wire with the switch plunger in and power to both the orange and white wires with the plunger out. I have power to the tail light plugs and have run an additional ground wire.
I cleaned all rear grounds prior to adding the additional ground. I also installed new 1034 blubs and the switch is new. The wiring harness is new. So what's my next move? They worked fine before I started the body on restoration.
Thanks for your advice!
David # 5133
David # 5133
