Repainting Midyear Side Exhaust Rocker Moulding - NCRS Discussion Boards
  • Michael B.
    • November 1, 1984
    • 57
    I want to repaint the black strip on the rocker moulding used with midyear side exhaust. Any ideas on prep and type of paint to use?
    Mike
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Repainting Midyear Side Exhaust Rocker Mouldin
    Mike:
    The "spears" should be lightly painted with semigloss black. Krylon "semiflat" works well.
    Mask the area, and carefully scuff with Scotchbrite pad, or similar. Clean with prep-sol, then tack, apply three light coats.
    Be careful not to scuff the clear anodized aluminum.
    oe
    • Wayne K.
      • December 1, 1999
      • 1030
      Mike,
      Joe has given you good advice. I would just add that you should wipe them down with the prep-sol before doing any sanding or scuffing of the previous paint so you don't work any wax or other contamination into it. Also use a very fine scuff pad. If there are nicks or chips in the previous paint you will need to feather sand them and possibly prime and sand out so you have a nice smooth surface for the new paint.
      Wayne
      • Rob A.
        • December 1, 1991
        • 2126
        Mike,
        I've used Krylon semi-flat myself for years on various parts. I now use Plasticote semi-gloss instead. I've found that it more closely matches GM's original semi-gloss. It's just a bit less flat than Krylon. Try them both some time on a spare part and see what you think. You can't go wrong either way.
        • Michael B.
          • November 1, 1984
          • 57
          Thanks for the Advice *NM*
