67 Door Lock Knob Removal - NCRS Discussion Boards
  • George D. 31849
    I need to take off the door lock knobs on my 67 to add the plastic washers. How do I take that spring clip off? Would I use the same tool that is used for taking off the spring clip on window cranks?
  • mike mccagh
    Re: 67 Door Lock Knob Removal
    same tool as window cranks, same horsehoe clip as the handles, same methodology. good luck, mike
    • Wayne K.
      • December 1, 1999
      • 1030
      George,
      As per Mike or I've had success using a right angled pick. You could make one out of a heavy paper clip. I've never tried it but I've heard of others taking a rag behind the knob from the clips open end and pulling the rag forcing the clip off.
      Wayne
