My 58 worked fine until the left rear wheel bearing went out. Changed the bearing and now the posi clunks in a tight turn. Also inside tire squeels when you accelerate in a turn from a stop. Manual says perhaps wrong fluid but that dosen't make sense. Same fluid as before. Any ideas? Could I have done something wrong when changing the bearing? Any help is appreciated. Thanks.
58 C1 4:11 Posi clunks in turn
