Radial tires vs. bias ply - NCRS Discussion Boards
  • Ron Hambrecht
    I am putting my C2 in flight judging and need to know if I will take a bigger points hit by keeping "correct type" repro radials on, or getting bias ply non original tires with DOT markings ?
    I really don't feel like buying bias ply tires if they will take an originality points hit anyway.
  • Jean C.
    • June 30, 2003
    • 688
    Ron, I am certain that a lot of members much more knowledgable than I on this subject will comment on your query; however, my two cents worth is if the car is ever to be put on the road (and I certainly hope that is the case), you do not want bias ply tires. My '64 has Goodyear radials that are not 'correct type repros' and my '68 has red-stripe bias ply repros. The driving/handling difference between the two cars is incredible. The '68 seems to hunt, twitch and whatever other bad situation you can imagine, most noticeably when the tires are cold.
    Best regards,
    Charlie
    • Ron Hambrecht
      Re: Radial tires vs. bias ply
      Thanks charlie,
      I agree. I had bias ply on my 63 SWC, and the way I describe driving is that sometimes wheel I turn the wheel right or left, it feels like the body of the car is still going straight.
      On my 67 I have radials now, and wondering if I should invest in repro "correct type" bias ply just for judging ???
      • Donald M.
        • December 1, 1984
        • 498
        Ron, That's totally up to you. How badly do you want those extra points? Are you going for a Duntov? Will it be worth the $170. a corner for bias?
        Don
          • September 30, 1999
          • 710
          If you are going to try for a Duntov you will need a set of bias ply tires at least for the PV test. You can't pass a PV with radials on. Mike
