Can someone clear up ? on correct fasteners for attaching/tightening visor on support rod.? Paragon catalog pg. 107 shows kit 4 screws + 4 nuts. I thought the double sided slot screw was correct.(I know I have to alter a screwdriver to fit).. If so where can I order some of interlocking screws? I tried the all the catalogs, Could not find them. Regards, Don
C2 sun visor screws
Re: C2 sun visor screws
Don,
I think what you are calling a double sided slot screw, at least the female portion, is what Paragon calls a special nut. The special nut is what you need the altered screwdriver to tighten. You could also use a tack puller or a mini wonderbar nail puller, instead of the altered screwdriver, to tighten the special nut.
Jerry Fuccillo
#42179Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
Jack,
Similar, but with a flat paw, like used for carpet or upholstery tacks. The notch spans the hole for the screw, and the wedge engages the slots in the special nut. Boy, are we getting technical here!
Jerry FuccilloJerry Fuccillo
