'63-'67 SMALL BLOCK IGNTION SHIELDING - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Did the '63-'65 small block upper ignition shielding have a higher curved area to fit around a fuel injection distributor, as compared to the same, lower area on the '66-'67 shielding?
  • Michael H.
    • January 29, 2008
    • 7477
    Re: '63-'67 SMALL BLOCK IGNTION SHIELDING
    Rob,
    Supposedly, the new for 66 ignition shielding was designed to clear the also new for 66 larger open element air cleaner.
    • Rob A.
      • December 1, 1991
      • 2126
      Thanks...I hadn't thought of that, guess it makes sense.
      • Paul Reynolds
        My 64 shielding was used for both carb and FI. There was a clip in the back that was moved from one slot to another to ground the 2 different tach drive cables. I believe 63 and 65 were this way also.
