Where is date on1967 hardtop plexiglass?? - NCRS Discussion Boards
  • larry linkous
    Can not seem to locate it. Thanks Larry
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Where is date on1967 hardtop plexiglass??
    Yea, I think that is pretty common. My original 67 has no discernible date either.
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      If you can find the stamp but no date, there probably isn't one. If you can't find the stamping, the positioning wasn't always perfect either.
      Try looking near or under the weather stripping around the lower left rear corner. It could be faint, or partially hidden.
      H. a. N. D.
      • Joe R.
        • March 1, 2002
        • 1356
        As I recall, the date code consists of a letter to the upper right of the logo and another letter to the lower left. The TIM&JG should have the details.
        On my original 67 window, only the upper right letter appears. I'm aware of at least one other 67 hardtop with the same situation. I've heard that the date coding was not always done correctly by the manufacturer.
        • Jim W.
          • February 1, 1980
          • 324
          My original 1967 black vinyl hardtop had the stamp in the lower corner but no date was visible.
          • larry linkous
            Mine too!! only letter I see is D
            What does the D mean?? Thanks
            • Bill Stephenson
              --------Add to all of the above the possibility that someone may have sanded and buffed out a scratch in the immediate area and you can guess the outcome.........Bill S
