Hi all, The 67 JG says ALL interior rear moulding screws are chrome phillips screws.(mine are blk.) Also do the four screws holding sun visors doubled sided screws or a nut on one side? The JG is not clear on this point. This Is being written at midnight but on my mind. Thanks again, Don
1967 interior moulding screws on coupe
Re: 1967 interior moulding screws on coupe
Don, better get out the lacquer thinner, all the interior rear molding screws are chrome phillips head per the JG. As for the sunvisor screws, I believe they are a very unique type of double ended screw/nut combination. You'd have to see one to know what I mean.Some owners make up a special tool from an old screwdriver by cutting or grinding out a recess in the middle of the tip so as to end up with a "forked" screwdriver to allow gripping the "nut" end of the sunvisor screw.
Don- Top
The screws are 3/4" #8 sheet metal with a #6 head Chrome plated. I found them at a local Fastener store. Bought a 100 for about $7 The screws that hold the 6" wide moulding in place have a captive trim washer on them. They had them too. Check your local trim shops for a source near you- Top
