Is it possible or is there any documentation that an A.I.R. air cleaner base was installed on a non A.I.R. 67 SB from the factory with the extra holes plugged with endcaps?
67 A.I.R Air Cleaner Base
Re: 67 A.I.R Air Cleaner Base
The 3 holer is the one I was referencing in my post....one for the breather on the back of the block on 327's, plus TWO holes for A.I.R. one for the 327 engines, one for the 427. The correct A.I.R. cleaner for 67 has two holes, but the bases are different (due to outlet locations) between 427 and 327. This "3 holer" covers both A.I.R. configurations, PLUS the base configuration 327 with rear block breather...... Craig- Top
