Fuel Pump 40083 - NCRS Discussion Boards
Fuel Pump 40083
  • Bill Bell
    Fuel Pump 40083
    After starting the '64 L84 and lettting it warm up in the drive this past weekend, it just died. Pushed it into the garage, and the trouble shooting began,. Spark from coil ok, and I have the Petronix Pointless Ignition System, and it looked ok. Checked the fuel filter, and no gas to injection pump. Upon replacing the pump, I noticed that the "PIN" that holds the spring/arm assembly in place was missing,, resulting in the "pivot point" moving so that there was no pumping action.
    If you have this problem,I have solved it by placing a bit of "weld" to this pin so that it does not fall out again.
    Re: Fuel Pump 40083
    Similar episode happened to Bill Wilhelm on the Rocky Mtn Chapter leg of the National Road Tour to Sun Valley, Bill. Remember?
    • Bill Bell
      Re: Fuel Pump 40083
      Yes Jack, I remember..thought it would be worthwhile for others to view and learn. don't you agree?
