1963 transmission yoke - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5186
    Can someone tell me the correct dimensions for the 63 transmission yoke. I have one that's 3 1/2" long but I remember something about a longer yoke and I'm not sure if it is used in 63. Thanks very much
  • William C.
    • May 31, 1975
    • 6037
    Re: 1963 transmission yoke
    Longer yoke was not necessary nor used in '63 because of the relatively fixed position of the rear end in the '63 car due to the IRS.
    Bill Clupper #618
    • Timothy B.
      • April 30, 1983
      • 5186
      Bill,
      Would my yoke that has a splined length of 3 1/2" be correct for a early 63 with a Borg Warner transmission?
      • William C.
        • May 31, 1975
        • 6037
        Length is ok, the '63 uses a coarse spline congiguration I believe rather than the fine spline used in '64 and later models, if the spline is good, go with it. If needed, the T-10 can also be converted to fine spline by using the trasns mainshaft from a buick or pontiac T-10, direct swap.
        Bill Clupper #618
