66/427 Enginge casting date? Correct?? - NCRS Discussion Boards
+ More Options
Posts
  • William B.
    • April 30, 1975
    • 942
    I am looking to purchase a 66 427/425 that has a block of 3869942, casting date of 12/18/65, owner not sure of the front pad (it still has paint on it) he thinks it is T1221IP? His car build date is 12/22/65. What should the front pad read? It seems to me the engine is wrong and should have been built a week before the car build date? He will let me wipe the paint off if I am serious about the car. Help, I need suggestions, before I go to view the car, the price is high. Thanks,
  • Don 42616
    Re: 66/427 Enginge casting date? Correct??
    Motor has to be first. The dates you show puts the car on assembly line 1 day before the motor. My 66/425 build date is 5-11-66. motor TO5-6-66. Don
    • William B.
      • April 30, 1975
      • 942
      Thanks Don, yours makes sense to me, 5 days between engine and car build date. What is your casting date for the block?
      • Michael H.
        • January 29, 2008
        • 7477
        Bill,
        Possible but highly unlikely. Even if the engine was assembled and shipped on the morning of the 21st, that would only be one day ahead of car assy on the following day. If we assume that your car was assembled at the end of the day on the 22nd, that would still only be two days from Tonawanda to car assy.
        If, however, the car was actually finished on the 23rd, which it most likely was, that would leave two entire days for shipping. Possible?
        • William B.
          • April 30, 1975
          • 942
          I wil not know the pad untill tomorrow. Could it be stamped 18, 19 , or 20 and make more sense?
          • Don 42616
            Yes *NM*
            • William B.
              • April 30, 1975
              • 942
              Re: Yes
              Don what is your block casting date?
              • Michael H.
                • January 29, 2008
                • 7477
                The 20th would be a possibility as the 19th was a Sunday. That would leave enough time to ship to St Louis by the 22nd.
                • Don 42616
                  Re: Yes
                  Bill, I don't remember offhand. I'll have to find flashlight & write it down. I know it precedes the deck stamp. I am thinking that the seller of the 66 your are looking at is misreading #s. Altho remember whenever you sell it you will have to explain the discrepency.
                  • William B.
                    • April 30, 1975
                    • 942
                    Could be assembled the same day it was cast??
                    If the motor was assembled the day 18th, it was cast or the day after 19th, his numbers would be correct?? I hope when I rub the paint off it's the 18th or 19th, would everything be correct then? I can walk away from this car if it looks bogus, but seller is saying it's correct.
                    • mike mccagh
                      Re: Could be assembled the same day it was cast??
                      if the engine was assembled on the 18th, there is no way that the block could have been cast on the 19th or 20th. if that's the case, walk away from the deal. mike
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        I think everyone is reading Bills dates backwards. He stated the block was CAST on the 18th, ASSEMBLED on the 21st and the car was built on the 22nd. The block cast to assy dates fit nicely, as far as I'm concerned. It's the body build date, the 22nd, that was in question, because it was only one day after the engine assy date.
                        • Don 42616
                          Many of the 427 motors out there are restamps or not original. I would think seller would remove paint & send you a high resoulation. You could put photo on this forum & you would get accurate advice. If you want an orginal car. The dates you quoted donot sound promising. I went thourgh this when I purchased my 66 & 67. Don
                          • Don 42616
                            Bill is saying that the build date is 1 day BEFORE motor stamp.No way is a production LINE going to wait for a motor on a delivery route.
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Not so. He is saying the body build is one day AFTER the engine assy date. I've gone back to his first post three times now just to make sure I wasn't having a senior moment.
                              Block cast 18 Dec
                              Block ass'd 21 Dec
                              Body buid 22 Dec
