Thanks to all who provided suggestions of where I should look for the disappearning coolant in my '65 small block. After I wrote the post, I got out the I/R gun and did some more checking.
When the car starts, it takes a minute or some to warm up, I guess the car is "clearing its throat". After a minute or so, it runs smoothly.
The I/R gun shows, when the car is warmed up, that cylinders three through eight are running at about 480-495 degrees, measured at the exhaust ports and manifold.
Cylinders 1 and 2 are running at about 375 degrees. Spark plugs are the same for each cyliner (AC-44).
Is the coolant "cooling" the front two cylinders? Are the cylinder heads cracked in the exhaust ports, or are the head gaskets bad? Brand new engine (professionally rebuilt and assembled by a reputable engine shop), 870 block, no overbore, rebuilt 461 heads, 1.94 intake valves, 1.50 exhausts. No porting done to the exhaust ports, etc.
Your comments are, as always, appreciated greatly. I need a winter project, but I'd rather repaint the car than tear the engine down (again!).
Mark
Mark
