Re: Ci locking gas cap ROB - NCRS Discussion Boards
  • Loren Smith
    Does someone sell a non-vented locking gas cap for a C1? I bought the Corvette Central locking gas cap, and still got the gas smell.
  • Rob Dame
    Someone suggested filling the vent hole with epoxy..worked well for him. Give it a shot. Rob
    • Stephen L.
      • May 31, 1984
      • 3158
      What happens when you run the engine, use the gas and create a vaccuum in the tank if the vent is plugged?????
      • John T.
        NCRS Financial Officer
        • January 1, 1983
        • 292
        The tank itself is vented. There is no need for a vented cap.
        John
        • Rob Dame
          Loren what year is your car? I believe the tanks are vented from 57 on up.
          Look in your fill door if it is vented you'll see the hose there. There is also a drain for that area. If the hose is missing from that drain you'll get a strong fuel smell. You sure the tank or lines are not leaking any?
          • Stephen L.
            • May 31, 1984
            • 3158
            Don't know about C1's...but C2's are only vented thru the cap. No extra hoses etc. and only 1 fuel line to the fuel pump.
            • Dennis A.
              • April 30, 1999
              • 1010
              Make sure the tank vent hose is not cracked or rotted and the drain hose from the nipple in the body of the filler cavity extends down through a rubber grommet in the underbody so spillage drains out on the road. For fuel Fumes preventive, also check the filler neck hose, they can become dry-rotted and replacing it with a radiator hose is not a good idea...
              • Loren Smith
                Rob - it's a 59. I replaced the vent hose, sender, resealed the sender, and the filler neck, etc. is in good shape and sealed well. I'm guesing it had to be the vented cap I was using before, but the locking cap did not help. I'm doing a full body-off resto right now, so I won't be able to try out a non-vented cap for awhile to see if it helps.
