Rear Height of a C2 Gas Tank - NCRS Discussion Boards
  • John L.
    • 409
    Does anyone know the rear height of a C2 gas tank. If someone could post the dimension, I would sure appreciate it.
    thank you
    john lolli
  • Wayne M.
    • March 1, 1980
    • 6414
    7" .....
    ... drawing straight line along bottom frame contact points, and another along the top, next to indentation for hold-down strap, then measuring between these two reference lines, at the rear. The tank has many indentations, curved corners, etc., so you'd have to me more specific if you need anything more precise, or taken at a different location.
    Just happen to have my '65 original tank on the bench for cleaning, new fill-neck gasket.
    PS. the rear height of a 36 gal tank is roughly the same, or even less; I assumed you're asking for a 20 gallon version.
    • John L.
      • 409
      Re: 7" .....
      Wayne -- yep the 20 gallon flavor -- thank you that is exactly waht I need.
