Casting numbers - NCRS Discussion Boards
Casting numbers
  • Lee Boyer
    Casting numbers
    Can anyone tell me what year and what cubic inch this is 3914638 (Casting)to223DR, 180156914 (pad) I want to build a 365 hp. 327 for my 61 and keep the orig. 283 2x4 for later use when i grow up. Some one told me that later 327 motors do not have the rear draft tube in the engine block? I want to keep all the orig parts on the new engine. Thanks
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Casting numbers
    1968 307 200 hp pass car block
      • 43240
      Re: Casting numbers
      Lee-----
      ....and the 3914638 block casting will NOT have provisions for a road draft tube. So, if you want to keep the original crankcase ventilation system, you'll need to find a 1967 or older 327 block. There's still some of these around.
