C-1 Bell Housing - NCRS Discussion Boards
C-1 Bell Housing
  • Fred S. Craprotta
    C-1 Bell Housing
    Does any one know the correct casting number for a C-1 Bell Housing dated G 17 7? Mine is 3733365 and I am told it is a passenger housing.
  • Donald L.
    • September 30, 1998
    • 461
    Re: C-1 Bell Housing
    Fred,
    The bellhousing for a 57-59 C-1 is #3733365. Looks like yours is for an early 58.
    • Fred S. Craprotta
      Thanks Donald, Since I consider this forum the ultimate in Corvette knowledge I will inform the others of their misinformation.
      • Dennis A.
        • April 30, 1999
        • 1010
        Don...
        Do you have the bellhousing casting numbers for the 60,61 & 62?
        • Donald L.
          • 461
          Dennis,
          60-61 #3764591 aluminum
          62 #3773553 aluminum
          • William C.
            • May 31, 1975
            • 6037
            At least per the judging guide, the 553 was used in '61 and '62, with the 591 being '60 only. 553 was also used on 409 engines thru '64
            Bill Clupper #618
            • Robert Willis
              My 57 still has the original bellhousing in it and it has side mounts for a passenger car. I think Chevrolet only had the one housing for Vettes and Passenger Cars in 57. In 8 the ears were gone. Fred, did get much more info reguarding Lance Hill ?
              Bob
              • Dennis A.
                • April 30, 1999
                • 1010
                Thanks for the numbers for 60 - 62 bellhousings.... I remember GM changed to Aluminum in 1960, and passenger cars used the same housing,except they had drilled and tapped holes on bulit-up bosses, while corvettes were plain.
                • Verne Frantz
                  Bill,
                  The '64 409 didn't use the 553 bell. It used a 360deg sandcast bell (forgot the number), the same one as the '65 Z-16 Chevelle. Also, the hi-perf 327 pass cars in '62 & '63 used the 553.
