correct volts C2 - NCRS Discussion Boards
correct volts C2
  • Don 42616
    correct volts C2
    I have an e bay new volt meter (I am becoming high tech,). At idle Battery shows 12.48V coil 12.50V alternator 12.40V resistor -2.25V ???
    I don't understand the later read. Don
  • William C.
    • May 31, 1975
    • 6037
    Re: correct volts C2
    Due to the pulsed current (points open and close-no steady state) the resistor is seeing when the engine is running, voltage cannot be measured at this point
    Bill Clupper #618
    • Stephen L.
      • May 31, 1984
      • 3158
      IF the engine was not running (Key was on) the points could have been closed. This completes the circuitry to ground with the resistor and coil in a series connection. You will then be looking at a voltage divider...
      Battery voltage-resistor-coil-points-ground. Try it with the engine running and see if there is an increase in voltage at the SAME point on the resistor...somewhere around 7-8 volts.
        • 15690
        Idle voltage should be 13.5-14.5. A fully charge battery is about 12.5.
        It sounds like the alternator has no or weak output.
