69 bolt finishes - NCRS Discussion Boards
69 bolt finishes
  • Greg L.
    • March 1, 2006
    • 2291
    69 bolt finishes
    I'm bagging and tagging some items for the plater and was wondering if someone could tell me the proper finish, if any, for these parts.
    2 rear spring bolts and 4 retainer washers that attach the trailing arms to the rear spring.
    4 bolts and lock washers that hold the rear spring to the diff housing.
    2 rear camber adjusting cam/bolt assy.
    Thanks Guys.
    • 43221
    Re: 69 bolt finishes
    Greg------
    spring end bolts-------black phosphate
    spring cushion retainers ("large washers")-----natural steel
    spring plate retainer bolts and lock washers------black phosphate
    camber adjusting bolt assemblies:
    bolts-----black phosphate
    cam attached below bolt head-----natural steel or black phosphate
    seperate cam (bolt end)-----zinc plated
    • Greg L.
      • March 1, 2006
      • 2291
      As always Joe your response is much appreciated. Thanks.
