'67 Signal Stat Hazard Flasher, need more detail - NCRS Discussion Boards
  • Daniel E.
    • April 30, 2005
    • 145
    Are either of these a correct hazard flasher for a 67? The TIM&JG 4th edition doesn't provide much detail for the Signal Stat flashers. If these aren't correct, additional details or pictures of what is correct is appreciated.
    Daniel
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: '67 Signal Stat Hazard Flasher, need more deta
    The #170 Signal Stat "gold finish" flasher is correct for the Hazard flasher, as well as the #175 "green finish' Neither will reference "DOT".
    Check out page 46 in your TIM&JG for a description.
    The Turnsignal flasher will be a yellow plastic #323 Non Dot flasher attached to the side of the center console area with a capacitor attached to it.
    • Daniel E.
      • April 30, 2005
      • 145
      Steve,
      Thanks for the information. In addition to the Tung Sol #323, the Signal Stat #145 is accepted.
      Daniel
      • Peter L.
        • May 31, 1983
        • 1930
        Daniel - While the Signal-Stat 175 is an acceptable Hazard Flasher for a '67, I would expect it to have an anodized green cover with 175 and Signal-Stat embossed on the top of the cover as the #170 example in your photo. The silk-screen versions of the "175" are later versions. Pete
