Help with 1967 Briggs Stratton original keys - NCRS Discussion Boards
  • Louis F.
    • September 30, 1991
    • 132
    On a 1967 Corvette,do the numbers stamped in the original keys have any significance to the car they were originally assigned to? Are the numbers sequential? Thanks, for any help.
  • Rick A.
    • July 31, 2002
    • 2147
    Re: Help with 1967 Briggs Stratton original keys
    each of the lock cylinders will have the same "key number" embossed as the key to which is assigned - sequential numbering, don't know about that
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Stephen L.
      • May 31, 1984
      • 3158
      The numbers stamped in the "knockouts" of the keys are the codes for the locks. Each number/character is significant to a locksmith in making a new key from the code without having an existing key. The alpha character on a 67 will appear in a particular sequence of the entire code. If you want to know what the correct code is for a particular lock you can remove the lock from the car. The code will be stamped on the side of the lock cylinder. I believe a locksmith can also decipher a code from an existing key...... have never tried this approach.
      • Joseph T.
        • April 30, 1976
        • 2074
        I bought a 57 Fuelie that had been in storage for 35 years and the keys were lost. I took out the passenger door lock and a locksmith made a key from the code on that lock cylinder.
        It worked perfectly in the ignition..
