Gas door emblem; Need Help - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    I am reassembling my 68 coupe and the MCRS Judging Manual states that the gas door crossed flag emblem should be held in place with spin rivets for cars assembled through May of 1968. My build date is May 12, 1968. What are spin rivets,where does one get them, how are they applied? It appears the emblem I have is meant for spin rivets as the "acorn" nuts that I purchased from one of the vendors slide on and off freely as the studs on the back of the emblem are only approximately 1/8 to 3/16 inches long.
    The judging manual states screws are not to be used until the 69 model.
    Any suggestions or advice appreciated. The emblem cost $54 and is not usable as is.
    Kurt # 26406
  • Jim B.
    • July 31, 2002
    • 146
    Re: Gas door emblem; Need Help
    Kurt
    I am an original owner of a 68 convert built in July of 1968 and my gas door has spin rivets. They are in good condition so I don't want to remove them to repaint the door. This will be a problem. In addition, any of the replacements I have seen are not the same as my original spin rivet type. It looks like the factory had studs on the emblem which went through the mounting holes and then they used a machine of some sort to break and twist-spin the studs causing them to expand at the hole and break off. I have no idea how this would ever be replicated, but to be sure only a very few folks would ever be able to tell.
    Jim Boudreaux
    #38390
    Jim Boudreaux
    LA Chapter, NCRS
    _____________________________
    1968 British Green Convertible 327/350HP Original Owner
    2002 Z06 Black on Black Original Owner
    2007 Z06 Velocity Yellow w/Black/Titainium Original Owner
      • 43241
      Kurt----
      The 1968 gas door emblem was designed to be used with the "peened" retention; it is different than the 1969 emblem in that regard as the 69-73 emblem has threaded studs. The 1968 emblem is reproduced and, if your emblem retaining studs have no evidence of threads, then that's what you have.
      Originally, a special tool was used to "peen" the ends of the studs; there was no "rivet", per se, and the ends were not "spun". I don't know how one could obtain the special tool used for peening these.
      • Geoff C.
        • May 31, 1979
        • 1613
