wires on coil: question - NCRS Discussion Boards
  • rick spears
    i'm just about ready to fire up the 73coupe that i have been restoring for almost 9months now....just want to make sure of something. there are two little wires that go to coil, one comes from the wiring harness and one from the distributor. i hooked up harness wire to positive post and dist. wire to negative post. is that correct?? thanks, rick
  • William C.
    • May 31, 1975
    • 6037
    Re: wires on coil: question
    Yes, the system grounds thru the distributor
    Bill Clupper #618
    • rick spears
      thank you bill....i appreciate it!
      rick
