C1 58 Horn Wiring - NCRS Discussion Boards
C1 58 Horn Wiring
  • Ken Susnjara
    C1 58 Horn Wiring
    I can't seem to figure out how to wire up the horn button. I was told to solder the pig-tail wire to the slip ring in the steering column. There does not seem to be a hole through the center to route the wire and if it is routed on the outside, it looks like it can only be soldered to the top slip area which doesn't seem right. I could sure use some help. Thanks.
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12740
    Re: C1 58 Horn Wiring
    There should be a small slotted hole in the steering culumn half way under the dash. This is the exit point for the horn wire. From there it routed outside the steering column, as part of the main harness, through a grommet in the firewall towards the horn relay.
    greetings,
    Rob
    Rob.
    NCRS Software Developer
    • Ken Susnjara
      Thanks Rob. I've got it routed that way and the horn works when I ground the pig-tail wire. My question is how and where it attaches to the slip ring.
      • Ed Jennngs
        The wire is normally soldered to the bottom of the upper shaft bearing.
        • ken Susnjara
          Thanks, I finally got it sorted out. I didn't realize I had to remove the slip ring - bearing first. Once removed it was easy.
