Headlight Motors 1963 - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    Where can I locate a technical drawing for the assembly of the headlight motor system for a 1963? (Looking for the gear drive system) I believe that Bubba worked on my headlight light motors.
    Thanks for any help!
    Ray # 36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Stephen L.
    • May 31, 1984
    • 3157
    Re: Headlight Motors 1963
    Some of the parts vendors have break downs in their catalogs
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks Steve
      I checked through some catalogs and shop manuals with no luck. I found pictures of the parts but not a sequence of order to install.
      I will keep looking.
      Ray
      Ray Carney
      • Paul Reynolds
        I think I found the "exploded view" in the LICS catalog.
        http://www.licorvette.com/pdfcatalogfiles/cat23/04.pdf
        • Wayne M.
          • March 1, 1980
          • 6414
          Ref. GM Corvette Parts Catalog exploded view
          The P & A 30B. It's quite clear on the order of motor assy. Sheet 2-11P in my '53-70 parts catalog.
          LICS and other aftermarket parts catalogs usually base their artwork on the GM source.
          • Ray C.
            • June 30, 2001
            • 1132
            Re: Ref. GM Corvette Parts Catalog exploded view
            Thanks Wayne & Paul
            I found the drawing in the Parts and Accessories Catalog. Would you happen to know the direction of the cup for washer part # 4238082? The reason I said that Bubba must have been in these assemblies is that one washer is cupped towards the electric motor in one assembly and the opposite direction in the other.
            Thanks for the help!
            Ray
            Ray Carney
            • Harry Sadlock
              After you save the picture. Rename it and add ".jpg" as the name extension.
              Harry
              • Craig S.
                • June 30, 1997
                • 2471
                Ray - If I recall correctly, the convex side of the cupped washer faces the smller washer which contacts the gear. I beliver the convex washer (cup washer) applies pressure to cotrol play.....Craig
