1976 L-82 Rearend Question - NCRS Discussion Boards
  • Christopher J. Bunsey
    My differential cover is cracked by the bolt hole, and I want to replace it with an original. Are the covers stamped, and where would be a good place to find a good used one?
    Thanks!
    Chris
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 1976 L-82 Rearend Question
    Chris - Carlisle would be a great place. Other than that, places such as IKERDs have them, but they probably are not willing to sort through them for dates.....they have a cast in date on the flange by the fill plug on the passenger side after 1967. Also, there were several casting numbers, which is on the rear between the mounting flanges.....on the top (upside down if I recall)......Craig
