C1 Valve stem source - NCRS Discussion Boards
  • Kenneth Bingener
    Just put wide white radials on my driver 58s stock steel wheels. Previous posts recommended using steel valve stems to keep the hubcap from rotating and/or avoid cutting the rubber stems. Can someone suggest a vender that carries these that fit the larger 0.6" hole? TIA Ken
  • David Lyon
    Re: C1 Valve stem source
    I purchased a set from CC a year or so ago. They wouldn't go through the hubcap hole. For my driver, I put in short stems with extensions. I'd be interested in who supplies the long stems with steel shanks. Would like to use the correct valve caps I purchased.
    David
    • Rob Dame
      I got mine from Napa about three years ago.
