C2 Distributor judging...hole, no hole - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Confused as usual...tach drive distributer with part no. 1111196 (67 350hp) and 5B7 (Feb 7, 1965) date. Hummm....67 application with a 65 build date??????? No comprendo!... Any theories...?
    Also, 1965 JM states originals did not have a HOLE in the casting opposite the tack drive. This one does... Hole no hole...what's the deal? When did the casting hole come in?
    JimV
  • Craig S.
    • June 30, 1997
    • 2471
    Re: C2 Distributor judging...hole, no hole
    I would guess the casting is from a later year since it has the hole, or has been modified. The band was probaby a repro band someone gave the P/N and date code.....and voila.....there you go!....Craig
    • Mark #28455
      somebody drilled a hole
      very common especially before numbers mattered to drill a hole like the later ones and insert a bushing to limit wear on the inside of the case.
      • William C.
        • May 31, 1975
        • 6037
        Re: somebody drilled a hole
        Hole apperaed around 1972.
        Bill Clupper #618
        • Jim V.
          • November 1, 1991
          • 587
          Thanks Craig, but wouldn't make sense in this application, since the car is a 65 SHP...why resto a 67 band on it? Anyhow, who knows?
          I can hear the cringing, but anybody ever epoxy over the hole?
          Thanks!
          JimV
          • Wayne K.
            • December 1, 1999
            • 1030
            Jim,
            I recall reading JB Weld works.
            Wayne
            • Craig S.
              • June 30, 1997
              • 2471
              I was thinking someone resto'ed it for a 67, but later stuck it in your 65.....hard to say, but doubtful original.......Craig
