1960 brake drums - NCRS Discussion Boards
1960 brake drums
  • Howard M.
    • June 30, 2000
    • 124
    1960 brake drums
    As a new owner, while rebuilding the brake system on my 60, I noticed that the right rear drum (3752623) does not have a balance weight attached. The other 3 do. Is it reasonable to assume that the drum was checked and did not need to be balanced or that the operation was missed somewhere along the way and needs to be done now? There is no indication that a weight was ever attached.
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 1960 brake drums
    Assume it didn't need one.
    • mike mccagh
      even if it had one and ole bubba removed it, it'll probably not be noticable. mike
