Color on 59 corvette - NCRS Discussion Boards
  • David B.
    • July 31, 2004
    • 15
    On the back of the upper and lowwer eyebrow moldings is the color supposed to be flat black, satin black or a gloss black?
    Also on the side spear blakplate, they appear to be painted black over a chrome finish, is this correct or should they be painted at all?
    As I was polishing the rear bumper I noticed that one of the license plate lights was loose, the lens that is, I took it off but could not get at the lens, it appears to have three rivets to keep the bulb holder in place. Am I right or should I pry a little harder to get the bulb holder off?
    Thanks for any help you can give me!
  • David Lyon
    Re: Color on 59 corvette
    David,
    Fourth edition 1958-60 NCRS Corvette Technical Information Manual and Judging Manual says on page 36, "outer grille ports" are "semi-gloss black". I can't find the reference, but the new side spear back plates I ordered from CC came semi-gloss if I remember correctly. As far as the license plate light bulb holders, they should pop-out. They are they same configuration as the bulb holders in the instrument panel. They are probably just corroded. Give them a little shot of PB Blaster or similiar lubricant. I have a '58.
    David
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12740
      Hi David,
      The lens can only be replaced (or tightened by putting in a new spongy gasket by drilling out the rivits. I replaced them by tiny screws myself (I know it's cheating but know-one will know if you don't tell anyone)
      greetings,
      Rob.
      Rob.
      NCRS Software Developer
