Replacement Engine - NCRS Discussion Boards
Replacement Engine
  • Ray C.
    • June 30, 2001
    • 1132
    Replacement Engine
    If an early 1960's (C-1) engine was replaced under warranty what would have been stamped on the block (cylinder case) pad?
    Thanks! Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • William C.
    • May 31, 1975
    • 6037
    Re: Replacement Engine
    Depends, could be a CE number, could be Blank, could be something stanped by the dealer.
    Bill Clupper #618
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks Bill
      Would there be any other indicators that would identify a factory replacement block other than the stamp pad, casting number or casting date?
      Thanks for your help!
      Ray
      Ray Carney
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Ray, I believe your engine pad...
        ...would be blank IF it came as a service replacement fitted case or long block from Chevrolet and the dealer or nobody else fooled with it. I think the CE stampings started later.
        • Ray C.
          • June 30, 2001
          • 1132
          Re: Ray, I believe your engine pad...
          Thanks! Dennis
          Ray
          Ray Carney
