The Dana Model 36 Differential.............. - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    ..........fluid capacity does not appear in the Owners' Manual, or in the Shop Manual. Does anybody know the value? Also, is there a difference in the capacity between the model 36 and the model 44?
    Joe
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: The Dana Model 36 Differential..............
    The 44 is bigger physically, so I would assume it holds more. I don't have stats on either one.
    • John M.
      • January 1, 1999
      • 1553
      Joe,
      I just filled the one in my 59 resto-rod, and it used about 1.5 quarts of lube.
      My Dana 44 still uses less than 2 quarts to fill.
      Regards, John McGraw
      • Joe C.
        • August 31, 1999
        • 4598
        John:
        Thank you, that is the best response that I have gotten to date. I have posted this same question on a couple other "C4 friendly" forums, but have gotten back no valid information.
        For some strange reason, I have to believe that there is no (easily available) published data on this. Because there is no drain plug, I only want to ensure that I remove all of the old lube with my suction tool. The only way to verify this, is to measure the removed fluid.
        I will use your "about 1.5 quarts" estimate as a guide. The next step, will be to contact Dana-Spicer Corp. for information. If I have no luck there, yours will be the sole basis.
        Joe
