C2 Hurst Shifter NCRS Deduct....Judge Help! - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Is it true you get a full 25 pt interior deduct, and the 25 pt opps reverse lockout deduct?
    I am trying to justify avoiding the headache of swaping out the Hurst with the OE.
    JimV
    Re: C2 Hurst Shifter NCRS Deduct....Judge Help!
    Yes, I would expect a full deduction for the presence of a Hurst shifter vs. Muncie linkage during Flight Judging because the objective is to restore the car to the configuration it left the factory in absent any dealer/owner inspired alterations. Since a Hurst shifter was never an option for Corvette, it's a hard stretch to NOT view this as anything except a dealer/owner inspired change and the rule book calls for a full deduction for such changes...
    Now, as far as the 25-point deduction for the Hurst shifter as part of the Flight Judging Operations section, I don't see that as real. Why?
    Well, there are 25-points associated with each line item on the Flight Score sheet in Operations and the line involved reads:
    "Reverse lock-out or neutral safety switch & park brake function"
    Since it's a manual transmission, mid-year car, there is no neutral safety switch, so the line item reduces to judging the operation of TWO items: (1) the reverse lock-out feature, and (2) the parking brake. That divides the available points evenly between the two items.
    Since the Hurst shifter does NOT have a reverse lock-out feature (beyond moving the shifter appropriately), I'd expect a good judge to allocate 12-points to the shifter and 12-points to the parking brake function....
    • Jim V.
      • November 1, 1991
      • 587
      I follow your logic. The total hit would then be 37 pts. (25 interior, and 12 opps.)
      Maybe the work and expense is justified. Let see...parts $300, labor ???, cost/point...hummmm....
      Thanks Jack!
      JimV
      • William C.
        • May 31, 1975
        • 6037
        At less than $10/point, a relative Bargain!
        Bill Clupper #618
