Mid Year Dash Replacement - NCRS Discussion Boards
  • Jeff H.
    • March 1, 2004
    • 5
    Does anyone know of a source where I could purchase a replacement dash for a mid year with center AC outlet? I have searched online but can only find LH and RH dash pads. Does someone make cores?
    Any help would be appreciated - Jeff
  • Geoff C.
    • May 31, 1979
    • 1613
    Re: Mid Year Dash Replacement
    If you are referring to the center fiberglass dash section without the humps, there is no repro. Even when GM sold this fiberglass dash panel it had no AC slot or even a radio slot. So even if you find a new discontinued one, it will not be cut. You choice is limited to adding the slot yourself, or searching for a used original dash from a factory AC model.
    Geoffrey Coenen
    • Jeff H.
      • March 1, 2004
      • 5
      Thanks Geoffrey. I suspected that was the case. Any suggestions where I could find a used dash panel? Perhaps Paragon?, they look like they might have a fair selection of used parts.
      Jeff
      • Eugene B.
        • May 31, 1988
        • 710
        Jeff,
        You may want to give Paul Tracy a call. Tracy Performance is located in Roseville, MI. His telephone number is 586-772-0000. He has a lot of used Corvette stuff.
        Good luck,
        Gene
        • Bill Stephenson
          Gene,
          -------Tracys first name is Dennis. He may have the hard dash but I would bet on Paragon if I only had enough money for one phone call............Bill S
          • mike cobine
            Mid Year Dash Replacement - how soon?
            I see dashes frequently on eBay and at swap meets. You have Carlisle coming up in August. How soon are you needing this?
