1959 Trunk Mat - NCRS Discussion Boards
1959 Trunk Mat
  • Jeffrey C.
    • June 30, 1995
    • 53
    1959 Trunk Mat
    I need some direction on where to find an exact reproduction floor mat for the 59. I called Al Knoch last week and he is having vendor problems and is unsure when he will have the mats available. This is a 30 point item for judging and regional is the goal in May. I originally used a late 60 mat as this was all that was available when I built the car.Mat #3761486 with 59 in circle in lt front corner and US in circle in rt front corner. HELP!!
  • L. Taylor (#16468)
    Re: 1959 Trunk Mat
    I don't have many suggestions for you except the regular Chicago Corvette Supply, Corvette Central or check past Drivelines. Not everything gets sold. However, somewhere along the way there were made a ton of 59' mats that had all the correct numbers, but the "59" was a "56" instead. I had to return two from different vendors, (AK) included. SO ASK FIRST when you do find one.
    • Bob Babcock
      Re: 1959 Trunk Mat
      Got mine from Rick at Western Corvette 800-73-4644 Bob
