c1 front suspension - NCRS Discussion Boards
c1 front suspension
  • Verle R.
    • March 1, 1989
    • 1163
    c1 front suspension
    C1 front suspension squeek when suspension is flexed...over small bumps or pushing down on front fender.
    I have greased all lub points with suspension at full extension, with full load and points inbetween. It still squeeks.
    I can see grease come out of each place when I grease it.
    I lubricated the swaybar bushings and grommets.
    Looking for ideas and suggestions.
    Thank you,
    Verle
  • paul bowers
    Re: c1 front suspension
    verl,
    could the front springs be rubbing against some other metal part
    paul
    • Wayne P.
      • August 31, 1975
      • 1025
      Shocks can do this also, or shock bushings.
      • Verle R.
        • March 1, 1989
        • 1163
        I lubricated the shock bushings as well as sway bar bushings.
        Any other ideas?
        Verle
