62 Front inner fender replacement - NCRS Discussion Boards
  • Eric Eade
    Hi again, I am in the process of planning the repairs and rep work to the body. Fortunately the only area that needs any major attention is the inner fender panels that have been notched, spliced and patched together over the years. I have decided to replace the panels but wanted to check the board for any advise and tips before I start. Also, I have heard the Legendary makes match mold panels but waanted to see if any other sources are around. Thanks, Eric #31337
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 62 Front inner fender replacement
    Corvette Image in Gresham Oregon 1 800 550 1200
    • Gary Bishop
      May I suggest that if you are not going to have the car judged have the 'Z're-enforcement bars used on `58s put on under the fenders directly under where the molding go. They will give you extra support to the fenders when you are working in the engine compartment and stop any flexing.
      • Eric Eade
        Thanks for the responses. I do plan on judging after it comes together so I will try to avoid the "Z" bars. I appreciate the source info. Eric
        • Don Shirey
          Eric, Eckler's panels are made by Corvette Image. Buy through Ecklers and you can get a 10% discount. There are a couple of rules, check it out.
          Don 31553
          • Eric Eade
            Re: Corvette Image fenders
            Don, It seems that Corvette Image supplies most of these parts. I called them the other day and had a price quote plus shipping. I was wondering if anyone has hands on experience with these parts to report how well they fit and follow factory appearance. I have toyed with the idea of repairing the ones that I have but this would require some creative splicing and I doubt if they will be strong enough withstand cracking during use. Anybody have a set of the originals sitting around? :-), thanks again, Eric
            • Mark L.
              • January 1, 1996
              • 121
              Eric, I replaced the left side inner fender on my '58 with one I bought from C.C. which I believe are Corvette Image units. Aside from it being a bit too shiny compared to the finish of the originals it fit very well with little or no "massaging". The front lower valance panel, from the center of the headlights down, was also from C.C. and fit perfectly as well. On the other hand I bought the rear lower valance panel from C.C. and it was a NIGHTMARE.
              • Eric Eade
                Mark, I am curious about your replacement experience. Drop me a note some time as I have a few questions about removing the old piece. Thanks, Eric
