'66 350HP CHAMPION PLUG RECOMMENDATION - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I checked the archives, but didn't find exactly what I was looking for. I like Champion plugs, and would like to install the best ones for combination city and highway driving. Engine is completely stock and unrebuilt. Unless someone has a better recommendation, I guess I'll just find a conversion chart from the recommended AC plugs in my owner's manual to find the corresponding Champion plugs.
    • 43240
    Re: '66 350HP CHAMPION PLUG RECOMMENDATION
    Rob-----
    I'd recommend going with a Champion J12YC or an RJ12YC if you want to use a resistor plug. If these don't prove hot enough for your driving situation, then go to a J14YC or RJ14YC. There is no J13 series plug now available.
    • Larry L.
      • May 31, 1993
      • 101
      I too have a 66 327 350 HP. I gave up on the AC44's, For the last 20 years I have been runing AC43S. The extended tip makes the plug act as a variable heat range plug.
      Use an anti seize lube on the threads and torque to spec.
      If you use a set of resistor plugs always check the resistor value - it should be be between 4 and 12 K. Anything over 12K will cause you touble after the plugs get a few miles on them.
      • Mike McKown
        AC 43S is way too cold for street use. AC 44 is too cold for anything but all highway driving. Use AC R45S and you will be happy.
