Prep and Paint of 65-66 Steel Wheels.. - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Need to refinish some original 65-66 steel wheels. Any thoughts on dipping vs media blasting as well as paint vs powder coat.
    JimV
  • Kent D.
    • February 1, 1992
    • 100
    Re: Prep and Paint of 65-66 Steel Wheels..
    Powder coat will crack under pressure so you will need to not have it under lung nuts. Also the wheel weights and hub caps will knock off the powder coat. I would use DB 90 primer and then paint them.
    • Jim V.
      • November 1, 1991
      • 587
      thanks for the heads up on powder coat. BTW what exactly is DB 90 primer
      JimV
      • Mike G.
        • January 1, 1991
        • 418
        PPG DP90 LF -- Black 2-part epoxy primer, lead free.
        • Jim V.
          • November 1, 1991
          • 587
          Epoxy primer.... & black paint
          Without a spray gun setup...what is comparable in a can?...
          Thanks Mike and Kent..
          JimV
          • Kent D.
            • February 1, 1992
            • 100
            Re: Epoxy primer.... & black paint
            How much where you going to pay to have your wheels powder coated? Find a shop to prime and paint your wheels.
            • Jim V.
              • November 1, 1991
              • 587
              $100 bucks....Doubt if I can get paint shop to talk to me for that much....let alone pay for the paint....
              • Peter M.
                • February 1, 1984
                • 361
                If you are looking for info re correct factory original paint - below ebay item will be of interest for guidance.
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  eeGads..man Buy yourself a $19 paint gun
                  from harbor freight and go to local paint jobber for the material. Even a elcheapo air compresser will drive this setup. You should know by now that Corvette restoration is a hopeless disease that can only be treated with tools, tools and more tools to faciltate the end product...
                  Besides, it's much more fun to do it yourself..
                  good luck,
                  tc
                  • Jim V.
                    • November 1, 1991
                    • 587
                    Tools.....
                    Yep...ya make a valid point. I just gotta figure out how to get all my wife's and kid's stuff out of MY garage for all those tools...
                    • Harry Sadlock
                      Re: Tools.....
                      Jim, I suggest you have the wheels inspected to ensure they are not bent anywhere, especially the rims. This will help with the balancing process and help to have the weights installed on the inside.
                      Harry
                      38513
                      • Tracy C.
                        • July 31, 2003
                        • 2739
                        Re: Tools.....
                        I know just how you feel Jim. My wife and 4 kids seem to believe they have equal billing in my garage too. We've got clothes,toys and stuff that hasn't seen the light of day for 15 years packed away out there.
                        I finaly gave up this summer and started to build me a 30 X 60 metal building out back. This will hopefully provide much needed space to get serious with completing my restoraion project. I've got the floor down now. The building will be up in about a month. I can't wait!
                        good luck on your end too,
                        tc
