c1- 1958 dash inset - NCRS Discussion Boards
c1- 1958 dash inset
  • Susan G.
    • May 31, 2005
    • 136
    c1- 1958 dash inset
    Hi, I have read the back issue with the article on replacing the dash inset and it says to cut the inset as it will be too big. I bought the inset from corvette central and it does not seem too big. Am is missing something. Also I am concerned about the wrinkles when you assemble the bottom chrome strip. Any ideas on how to not get wrinkles and what caused the wrinkles. Thanks in advance Susan
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: c1- 1958 dash inset
    I just did a 59. It was NOT too big. The aluminum is very fragile. If you push on it, it will bend. Handle it very carefully.
    • John O.
      • May 31, 1998
      • 480
      Hi Sue
      I just did one on my 62..It went in tight and fit perfectly. I bought mine from CC. What bottom chrome strip are you talking about?
      John
      • Susan G.
        • May 31, 2005
        • 136
        hi John, the bottom stainless strip that holds the insert in - is what I was talking about. The corvette restorer article referred to a ridge that it snaps onto and too much pressure causes wrinkles. My strips are very hard to shape and snap back on. Did anyone use epoxy or weld to hold it together? Is there anyway to add support to the back of the insert so it wont bend during re assembly. Thanks alot Susan
        • Kevin Riel
          I put an insert in my 59. I did not trim it at all. It did fit snug. I spot welded the stainless back on with a small MIG welder, however I know a lot of people use glue. I think either will work. You have to be careful, as the aluminum is fragile.
          Kevin Riel
          • John O.
            • May 31, 1998
            • 480
            Hi Sue
            I took the easy way out with mine. I sent my old one to Corvette Central and they install the new insert with the stainless all on and sand blasted the main insert backing. Once I got it back, it went in snug and fit perfectly.
            John
            • Susan G.
              • May 31, 2005
              • 136
              Hi John, I wish I had read this sooner. I burnt my first insert with a mig welder and just ordered my second insert today!!! Oh well next time I will wait for more responses. Regards Susan
              • John O.
                • May 31, 1998
                • 480
                Hi Sue
                Where did you buy it from. Maybe you can return it. Then call and send your unit in to corvette central and let them do it.
                Take care.........John
                • Garry Barnes
                  Susan,
                  I have used periodic beads of JB weld on the backs of these with good luck. Better than glue and you won't burn or scorch it.
                  Garry
