'65 AIM - Help me read torques UPC C60 Sheet D5 - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    This sheet concerns blower, evaporator and STV plumbing. My copy's print is very dense in lower left corner; can't read the torque references in the little triangles. I think the first line/triangle is a "3", but can't read the second line (also, is the torque range 23-28 lbs.ft ?), nor can I decipher the third line (first) triangle [I think the second triangle on the same line contains a "7"). The final line's triangle is completely black, on my copy.
    TIA
  • Eugene B.
    • May 31, 1988
    • 710
    Re: '65 AIM - Help me read torques UPC C60 Sheet D
    Wayne,
    Per my copy, the torque specs are as follows:
    Line 1: 30-38 LBS.IN. (See caution Note SHT. D7.)
    Line 2: 23-28 LBS. FT.
    Line 3: 11-13 LBS. FT. 5-7 LBS. FT.
    Line 4: 10-15 LBS. IN.
    The numbers in the triangles are not legible on my copy. Thats why I indicated them by line number. I can't explain why there are two torque specs. on line 3. Hopefully your copy will help you determine.
    Good luck.
    Gene
    • Art A.
      • June 30, 1984
      • 834
      Wayne, Here is how the Triangle list reads:
      Top Triangle= #3 30=38 LBS.IN.(SEE CAUTION NOTE SHT. D7.)
      Second Triangle= #4 23-28 LBS.FT.
      Third Triangle= #5 1=13 LBS.FT. To the right of #5 is Triangle= #7 5-7 LBS.FT.
      Forth Triangle= #6 10-15 LBS.IN.
      Hope this helps
      Art
      • Peter L.
        • May 31, 1983
        • 1930
        Re: '65 AIM - Minor Correction
        Art/Wayne - Third triangle (#5) should read 11-13 LBS.FT. Pete
        • Art A.
          • June 30, 1984
          • 834
          Of course you are right Peter, tiping errer on my fart---my bad!
